Aller au contenu principal
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Questions au sujet de 135 Voir tout
2001 cavalier wire problems?
my cavalier has been a lil screwy since i replaced the radiator, my speedometer, gas gauge, and car temp gauge always read zero while i drive, also all the egine lights pop up while im driving as well, also my license plate keeps going out randomly is this a fuse problem? or something else?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Jordan Lewis, it's to complex to be fuse issue. Double check all the wiring under the hood to make sure you did not accidentally loosen or disconnect and of the harness connectors. Your errors sound like a bad instrument panel. As for your engine light, I would start by taking to a place where you can get the OBD scanned. Autozone does it for free, and it will give you a better starting point. Here is a decent write up on how fix the instrument cluster. Hope this helps, good luck.
Indice 1
Ajouter une réponse
Jordan Lewis sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 3,268
