wont turn on when I take it off of it's charger.
My iPhone 3GS fell in some water, it wont turn on when I take it off of it's charger.
Any help?
The iPhone 5 is the current iPhone right now.
Any help?
Pyrus, first thing you want to do, is to stop trying to charge it and to no longer plug it in. This could make a bad situation worse. You definitely should start off with this guideIt is for a 3G but essentially the same procedure for your phone. After that change the battery. A once exposed battery is definitely a cause for plenty of headaches later on. You'll be surprised to find out how many errors a water damaged battery can give you ;-) After that, reevaluate, clean again and see what you get. Should even a new battery give you the same trouble, consider changing the dock connector. Hope this helps, good luck.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 248
