change loudspeaker of MacBook Pro 2012
hey is it possible to change the loudspeakers of an 15 inch mac book pro mid 2012?
(I'd like to build in some with better quality) if it exists ...
There are no internal speakers of better quality specifically custom designed to replace the stock ones. If defective, you can simply replace with the third party (matching Apple Part, which is no better than Apple's). If you are determined to upgrade the internal speakers quality, you can custom design of your own. Measure the sizes and sphere, then get boss mini sub-hoofer. You will need a soldering iron, soldering thread, heavy duty fixer solution and some other general instruments for custom cut, fit and assembly. Few millimeters mismatch may give a tedious feel while seating on the top-case.
It's not an easy job because the they are very carefully pressed in the solid plastic base, which can be easily pulled out though. Look at this picture that shows how simply but solidly they are affixed: http://support.apple.com/kb/TS3336
If you really mean it, you can. But, I'm not sure that you will get any solid sound output though. It will be a hakintosh sound, but, hey, you never know!
If I were you, I would custom configure equalizer rather than pressing hard to MBP.
I have a suggestion, that may seem ridiculous though. If you can get rid of Optical Drive, you will have quite nice space for custom built amplifier and speakers just at the Optical Drive Bay which can be powered right from the logic board battery connection. This may require even more research and measurements and also if you are dead committed.
If you liked it, accept it. Thanks.
Okay thank you it's just that I met an musician in holiday and he's working for apple too and he told me he had a mac Book pro with Bose loudspeakers. but i think it was a special offer by apple ...
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 364
