Aller au contenu principal
Tutoriels de réparation et de démontage pour des centaines de lecteurs optiques.
30 questions Voir tout
Question close
MPN difference and possible compatibility problems
Maybe it is a silly question, but however... I want to replace my optical drive for a mid-2007 Macbook 13", model UJ-857-C. I have found exctly the same model, but the MPN is different: 678-0557B against a 678-0557A. I would like to know if it could pose a problem of compatibility or if it depends only on the country the drive is manifactured in (one in China, the other in Indonesia).
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
It's the same P/N just a different revision A Vs B. The B version is the newer model and has some level of improvement over the A version. Even still you should be OK.
Indice 2
3 commentaires:
I just need to boot via DVD and reinstall the OS, if it is able to do that it is right for me. I mean, no firmware problems possible?
par
It's starting to sound like you have already tried and it didn't work is that correct?
par
No, I have not tried yet. I just wanted to be sure it could work before buying it. Thank you however ;)
par
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 226
