Aller au contenu principal
La ligne d'ordinateurs portables MacBook Pro a été conçue pour les utilisateurs professionnels. La gamme MacBook Pro inclut le MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", et le MacBook Pro 17" Unibody .
Questions au sujet de 15137 Voir tout
My MacBook Pro won't power up
Hi first of all thanks a lot for for any of the help you may give me. I tried changing my hardrive which I believe I did successfully problem is as since its been installed my computer died. It doesn't switch on even with the charger in its crazy it was working perfectly fine before and I've tried installing a different hard drive but still nothing.
Une réponse ! View the answer J'ai le même problème
Commentaires:
Ah just noticed the light on the charger comes on feintly but still doesn't switch on
par
Peter Czechowski, what are the last three digits of your serial number? This will help to identify your MBP.
par
ATm, I've tried leaving it to charge overnight didn't work I've tried hard resetting the smc I just don't understand it:(
par
Ajouter un commentaire
Fix Kits pour batterie de MacBook
À partir de $69.99
Buy Now
À partir de $69.99
Buy Now
1 réponse
Solution retenue
Double check all your connections... if you have a loose ribbon cable or \ connector it would cause the non-start issue. You might try How to switch it on without the power button? to eliminate the logic board as the cause.
If this Answer is helpful please remember to return and mark it Accepted.
Cette réponse est utile ?
Score 1
Commentaires:
i really don't understand where he is talking about i've looked on youtube but the place they're talking about doesn't exist on my laptop. either way i don't think its my keyboard otherwise there wouldn't be a dim light on my carve cable surely? i still can't see it being the logic board either considering it was after a hard drive update it didn't just happen out of no where
par
Ajoutez une réponse
Peter Czechowski sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 467
