Aller au contenu principal
Version revisitée de l'iPhone 3G avec une vitesse de traitement plus élevée. La réparation de ce modèle est similaire à celle du 3G et nécessite de simples tournevis et outils pour faire levier. Modèle A1303 / capacité de 16 ou 32 Go / coque en plastique noir ou blanc.
1500 questions Voir tout
Question close
Is 70% Isopropyl alcohol ok to clean an iPhone 3GS?
I was caught in a heavy rainstorm about 3 days ago and my iPhone died on me. I opened it up when I got home and dried off the components with a soft cloth as well as ordered a new LCD & Digitizer and installed those.
The screen works as it should but the backlight is still inactive.
My question is: Is 70% isopropyl alcohol enough to clean the logic board and connectors of the 3GS? I was planning on following the guide posted on this website inorder to do the fix but was just wondering if 70% was too little of an alcohol concentration.
Thank you for any help you may be able to provide.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
No. 70% isopropyl is 30 % water. Use methanol.
Indice 2
6 commentaires:
So if I were to soak or brush the contacts with it it would just ruin the phone further? Also, would 90% or 99% be the right choice then?
par
90% + should be fine.
par
And 90%+ is available at places such as Target or Walmart correct?
par
Andrew Novotny, I get my stash of 99% through my local pharmacist. The larger retail stores are not really good in getting those items, not a big selling item for the.
par
I don't know, I use Methanol. Call them.
par
Afficher 1 commentaire en plus
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,694
