Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Netbook de 2008 ; modèle ZG5 AOA150-1691 ; écran 8,5" ; processeur Intel Atom N270 1,6 GHz
Why can't I flash bios with black screen of death?
Black screen of death...bios trick not working for me. I see many others had this problem. But i never see a fix for the people that arent able to flash bios? The little battery inside is bad maybe? What all can it be? External display does not work either....please someone find a fix for me!
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
4 commentaires
To begin with, which instructions did you follow exactly? Did you follow the correct or incorrect rections? I guess it dont matter cuz neither of them worked huh? None the less here is the real instructions......or rections, if you prefer. "............................................................." ok, im lost. Im talking to myself. I may just put this lil puter through a wall and into a waste disposal unit. Ohhhhh my goooood this is good shiz. Im lit out my mind.....still needing help on this guys!!!!!
par
StickitRickit, did anything happen to your Acer? Why do you think that this is a BIOS issue??
par
ummm still around turkey? I dont think anything specifically. I just hoped it was a bios issue. I changed the RAM one day. May have been the wrong RAM. IT was a 5300s 2gb chip. Then a couple weeks go by without noticing any performance increase or decrease. My friend comes over all lit and dumb and pulls the acer off its desk and !FLOP! to the floor it went. It was still on and running fine. It worked for a few more days but I notice the performance is lacking moderately since it fell. I open it up to check the RAM chip is still in place and it was, put it back together and here i am. I may have pulled a lil tiny wire lose that connect momma board to the screen. but i cant imagine its my fault. i opened the thing up sooooo many times learning on it. thanks and sorry it takes me so long. i pay attention if you comment back now
par
Acer suffer from death by update mine was just 13 month old anything over warranty date is a bonus my sister's one lasted 14 months, I've tried every option in the blue screen menu, and the boot order cannot be changed the bios such as it is has M2523 in it and arrow keys don't work these things are junk and the customer service just directs you to their self help forums.
Don't but this cheap self distruct Asian crap!
par
Ajouter un commentaire
8 Réponses
Solution retenue
Hi, Here is a link to a service manual for your unit. Good luck.
http://tim.id.au/laptops/acer/aspire%20o...
Indice 1
1 commentaire:
Hope so gonna do it!
par
Réponse la plus utile
Thats easy:
get 3309.fd from e.g.
http://en.kioskea.net/forum/affich-95127...
rename it to ZG5IA.FD and put it on an USB-stick.
Switch your ZG5 off, put the USB-stick into the slot at the left side.
press "FN" + "ESC", keep it pressed;
press "Power ON"
release "FN" + "ESC"
Power LED will blink for 1/2 min. wait until stop blinking.
after that: switch off ZG5, pull out USB-Stick;
Power ON: yuppi!
Gruesse aus D: Axel Paulien
Indice 3
2 commentaires:
Tried your method and doesnt work
par
Plug in usb drive and hold fn+esc key on acer aspire one zg5 aoa150 and press the power key and the power light been blinking all the way for 30 mins and does nothing.tried battery plug in or without battery also doesnt work.what is the problem.
par
acer aspire 7745g not booting plase helfe
Indice 0
ACER ASPIRE 5734z not booting.. when i press power button. no light indicator on it! help please.
Indice 0
Got to acer drivers and manual section and find your acer laptop through its model number and download the bios for your laptop. when you open the folder you downloaded there will be a folder named "dos" open it and copy the files "FLASHIT" and the file with either a ".bin " or ".fn" extension, for example "P4LJ0112.bin" to a flash drive formatted in either FAT or FAT32 extension.
*Plug your laptop to a power source
  • plug in the flash drive with the files in it to the laptop
  • Press and hold the FN + ESC keys and press the power on button
  • when the laptop powers on press and hold the FN + ESC keys for 7 seconds and let it go
  • The Power button will start to flash leave it as it, will take about 10-20 minutes
  • If the laptop turns it self off after, remove the flash drive and power it on.
You should have your laptop up and running again.
Indice 0
please help me i have a aspire 5530 and the bios files are only flash32.exe and flash 64.exe . i dont have a .fd file?? please help
Indice 0
OMFG I was trying everything possible with no success..until I replaced BIOS battery and the computer miraculously turned on!!!
Indice 0
I just ordered a new CMOS battery since mine was only showing 2.48v. (ML1220 coin cell in case anyone else wants to order in advance)
Replacement only shows 2.70v but they are rechargeable so maybe that's not that bad? It says nominal voltage should be 3.6v...
Anyway, buttoned it back up with the new battery and same issue.
  • Still black screen.
  • insert usb with 'FLASHIT.exe' and 'ZG5IA32.fd' (formatted to 'FAT')
  • Hold 'FN + ESC'
  • power button flashes
  • and keeps flashing forever...
  • I've tried multiple flash drives and all 3 USB ports.
Indice 0
Ajouter une réponse
StickitRickit sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 33
Total : 55,608
