Aller au contenu principal
Model A1288 / 8, 16, or 32 GB capacity
451 questions Voir tout
Question close
Why's my touchscreen not responding? Error code -1 when restoring?
Hey guys. I'm new to this, but just wanted help before I decide to pry the iPod open. So anyway, I bought this iPod Touch 2nd Gen from my friend and he said that the touchscreen isn't working for some wierd reason. Anyway, after I got it home and connected it, I checked what's wrong. Low and behold the screen didn't work, and when I try to restore it, it just says that it can't be restored due to an error -1 which from what I understand is a hardware error. My main question is would this be a hardware error as in just the touchscreen causing the error or would this be a logic board error? Also, all of the thing's i've tried so far are connecting it to the computer and trying to retore it so if you have any other ideas, i'm open to them! Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Have you thought about replacing the digitizer?
par
Ajouter un commentaire
1 Réponse
Solution retenue
Error code -1 is a failed jailbreak and the device is bricked. the device is useless and the only way to possibly getting it working is to use TinyUmbrella or redsn0w to bring it back to its default setting. heavy research is need for this task before attempting, at this point anything is better then nothing since it cant get any worse then what it is.
i hope this helps and good luck
Indice 1
5 commentaires:
To be honest, i'm not too sure that it's a failed jailbreak because when I use my EarPods with the touch, and they have the inbuilt remote mic, I can play/pause music and control the volume, but I can't do ANYTHING with the touchscreen. I'll still try TinyUmbrella though!
par
if your right then there is vary little you can do to fix this. like finding what circuit or IC needs replacing.
par
Oh well, at least i'll have it for parts!
par
yeah that's always a plus
par
:) Thanks for the help at least!
par
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,113
