Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Samsung Epic 4G is the first US released version of Samsung's Galaxy S II. Also known as the Samsung Galaxy S II Epic 4G Touch.
How to Remove usb port because of damaged pin and solder new one
I need help in de soldering and placing my new replacement ..I can't seem to find help on this topic i dont want to buy the whole cable with usb port i wanna solder a new one in
Répondre à cette question J'ai le même problème
Indice 5
7 commentaires
will, what exactly is it that you are looking for? How to dismantle? where to find the part? How to solder it on?
par
how to dismantle the usb charger part correctly and install it correctly I already bought all the parts I need ..Bought a 5 pack of USB ports
par
Already have a soldering iron and the tools to take apart the phone
par
Thank you buddy... needed to know those easy details you just mentioned :) will report once I get this done
par
best of luck to you:)
par
Voir 2 commentaires en plus
Ajouter un commentaire
2 Réponses
Réponse la plus utile
will, I suggest you use this teardown to disassemble your phone. It is not a guide, but does give you a general idea on how to get it accomplished. Remove the logic board. Desolder the data connections from the micro USB port on the front. Desolder the four points that hold the port to the logic board from the back. Remove the port and replace with a new one, available at places like this. Reassemble your phone. Hope this helps, good luck.
Indice 1
4 commentaires:
My question is after unsoldering the four points, are the data connectors solder as well or no? i am also doing the same operation.
par
Yes they are.
par
so then i would also have to unsolder the data connectors?
par
Yes.........
par
One quick Q... which are the data pins that are for the ground from left to right?
Indice 0
Ajouter une réponse
will sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 6,990
