Aller au contenu principal
Repair your Dyson DC 14 vacuum cleaner with a part replacement guide.
Questions au sujet de 46 Voir tout
Why isn't my beater bar spinning?
The beater bar isn't spinning, the belt seems fine, the suction is good. The filters have been cleaned. I've had the vacuum for about 5 years and never had an issue until now. It also doesn't want to stand upright--but this could be an unrelated issue.
Répondu ! Afficher la réponse J'ai le même problème
Indice 25
3 commentaires
" It also doesn't want to stand upright "In my case the DC14 works fine but will not stand up on its own,.which makes it difficult when using the hose attachment. Please advise
par
The belt is still tight but will not turn when on.
par
Mine will spin for 30 secs then stops, I turn it on and it keeps doing the same.
par
Ajouter un commentaire
7 Réponses
Solution retenue
Hi @junie
What model is your vacuum cleaner? Did you buy it using a credit card? If so can you find the purchase on the credit card statement?
Update (03/24/2016)
Hi @junie
If you are using the motorhead attachment, have you pulled the bristle control to the out position (in other words not pushed in? It only comes out about a 1/4". Seen in the image, in between the bristle holder and the wheels.
Indice 5
3 commentaires:
My vacuum is a DC 23
par
A dyson DC 23
par
A Dyson DC 14
par
Réponse la plus utile
Your beater bar is not moving because the gear that it's belt sits on is full of hair, threads etc.
Unplug the vacuum.
Remove the beater bar cover using a large coin.
Remove the beater bar. This will take some patience and time.
Remove the belt.
The gear should have hair strands etc. wound around it.
Remove the hair etc.
Replace the belt.
Replace the beater bar.
Replace the beater bar cover.
Plug in the vacuum.
Thouroughly clean your carpet as it hasn't been cleaned well the last few times do to the vacuum not working properly.
Patrick
Indice 8
8 commentaires:
The DC14 has a clutch that engages or dis-engages the beater bar depending on floor type. You may need to replace the clutch. There are Utube videos that show how to do this. You can order the replacement parts online. Also videos on changing belts, etc.
par
Thanks so much for posting this!!! I've been trying to find a fix for a while and this was exactly my issue. The hair and debris had worked itself so far into the axel it was completely unobservable until taking off the cog that moves the brush. And because there was so much of it getting that piece off was actually quite difficult. At any rate, after removing the dense bunch of debris it is working perfectly now.
par
I changed the clutch in my DC14 and the beater brush still doesn't turn, any suggestions?
par
I've got a brand new beater bar on mine and the belts tight but Still not spinning.
par
Did all of the above: cleaned the bar, cleared the belt, aligned the pieces holding the bar in the housing were the right way... all good
Looked at the clutch belt.... it’s not “floppy” but I can move the clutch-motor belt by hand, it seems a little loose?
How loose would the clutch-motor belt need to be enough in order to stop the agitator bar from turning at all??? Any ideas ???
par
Voir 3 commentaires en plus
I've never had any first hand experience with the Dyson DC14, but this DysonMedic post and this other post might help steer you in the right direction. Good luck!
Indice 1
The first thing is to remove anything that's wrapped around the beater bar. You probably did this already.
Next take off the cover and look at the end caps on the beater bar. On my DC14, the end farthest from the belt tends to gather lint under the end cap. Use a tiny screwdriver or the pointy end of a nail file to dig out the lint. You may be surprised how much accumulates in that small space. Rotate the bar while doing this. The gap is larger at one spot in rotation, and it will be easier to dig out the lint at this spot.
Once all the lint is out, check that the beater bar rotates freely. Put the cover back on and you're set.
This would make a lot more sense with pictures. I hope you're able to figure out what I mean.
Indice 1
2 commentaires:
There's a YouTube video that shows this in detail. Look for "dyson dc14 brush stuck".
par
I've got a Dyson 7 and the brush won't go but belt is tight and the sucks up good but the brush isn't doing anything
par
I took the beater bar partway out and pulled away threads. The belt seemed fine also. I put all parts back on and voila! It was working. My guess is I may have been a little rough when vacuuming and jarred the bar out of place.
Indice 0
DC25
My wife got some table cloth jammed in the brush bar.
When pulled out suction ok but no brush bar rotation.
No hair or thread on bar to impede rotation
Followed these intructions see URL below, to remove brush bar.
Brush bar drive shaft seemed a little stiff and after a few rotations by hand seemed better.
Replaced brush bar and immediately worked.
Not sure what the diagnosis was ? drive shaft jammed ? some kind of protective jam.
Worth trying this simple routine before trying more complicated dismantle !!
https://www.youtube.com/watch?v=6Yc7h4Wg...
Indice 0
1 commentaire:
The switch to operate/engage or disengage the brush, wont push, obviously the spring has sprung. the power still switches. How do i reassemble the brush switch?
par
For my Dyson DC14 it was the bearings not being clean and they were not spinning. Easy fix with the help of these 2 videos
1)
https://www.youtube.com/watch?v=xVkbFv0D...
2)https://youtu.be/fdvRFE680u0
Indice 0
Ajouter une réponse
Kirstie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 55
30 derniers jours : 231
Total : 169,084
