Turns off when disconnected.
Try using a iPod dock same thing when I use a USB cable but iPod dock turns it on but and charges but once I take it off it turns off
What can that be
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Jon, sounds like a power issue. I'd start off by replacing the battery. Use this guide to change it. The battery is available at places like this. Once you got that accomplished, reevaluate. If that should fail you could have issues with the dock connector, i.e. broken, bend or corroded pins, as well as a faulty PMIC. Start with the battery since this will provide you with a known good point, should further trouble shooting become necessary. Hope this helps, good luck.
Image iPod touch (3rd Gen) Replacement Battery
Produit
$14,99
Cette réponse est utile ?
Score 2
Ajoutez une réponse
Jon sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 3
Total : 1,068
