Aller au contenu principal
La PlayStation 3 Slim est la deuxième version de la console de jeu vidéo PS3 produite par Sony Computer Entertainment. Elle est sortie le 1er septembre 2009.
465 questions Voir tout
Question close
No Video - Shuts Off With Blink Red Light
So I have a PS3 slim I'm trying to get working. The console won't output any video, and after being on for about 30 seconds or so it will beep and the light will change from green to red and start blinking until you push the power button, at which point it will stay red (as it would when it's off). I've tried HDMI and composite, and I can't get any video off of either. If I try resetting the video settings by holding down the power button it will just turn on and and then off after a few seconds but will not beep in between as it should.
I've tried switching out both the power supply and the hard drive with no luck. I plan on heat-gunning the video chips if you guys don't have any suggestions.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Is it up and running again? What was the problem? Mine caught the same disease...
par
Ajouter un commentaire
1 Réponse
Solution retenue
Yep thats the only way mate it sounds Like the Main Chip Has some Dodgy Solder Connections Reheating Both the Large Chips Is usually the Best option As in my experience with playstation 3s you can do one and it will turn out to be the other one. If you need a Guide Have a LOok at BGA Reflow PS3 on Youtube there are many a video that started me off fixing them :) and forgod sakes... Dont do the oven trick! i have Bricked Many a Board with that! invest in a cheaper heat gun if need be they do the trick... iv been using the same one for years!!
Good Luck!
Indice 0
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,194
