Aller au contenu principal
Tutoriels de démontage et réparation MacBook Pro, la ligne d'ordinateurs portables conçue pour les utilisateurs professionnels. À ce jour, la gamme MacBook Pro inclut des versions 13, 14, 15, 16 et 17 pouces avec des changements majeurs définies par les designs pré-unibody (d'origine), unibody, écran Retina, Touch Bar et SOC (système sur une puce).
19981 questions Voir tout
Question close
Keyboard backlight does not light, even after replacement.
I bought a used MBP, Early 2008 Macbook Pro 15". A1226, that came with a French keyboard, and the backlight was intermittent. I replaced the KB with a US one, and that works fine, except for the backlight.
When I use the F5/F6 keys, the [on-screen backlight] indicator moves, but no change in the light. In System Preferences I have tried automatic and manual control for the backlight - no change.
Nothing is blocking either the speaker grille or the webcam area.
Ideas?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Fixed it.
It turns out that the keyboard backlight connector is very position-sensitive. I went back in and reseated all the keyboard-related connectors (again!) and was finally able to get the backlight working again.
Tim O
Indice 0
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 640
