Aller au contenu principal
Le Samsung Galaxy S4, modèle i9505, dispose d'une caméra arrière de 13 mégapixels et d'un écran de 5 pouces et 1080 pixels.
Questions au sujet de 523 Voir tout
Replacing Volume button on Samsung S4
I recently got the Samsung S4. My volume button is bent and stuck. what tools would i require to repair it and can i get a replacement volume button from you guys ? thanks
Répondre à cette question J'ai le même problème
Indice 7
1 commentaire
Where could I find a volume botten
par
Ajouter un commentaire
9 Réponses
Réponse la plus utile
Stephen, here is a great video about how to disassemble your Galaxy. Looks like all that is needed are standard tools, best tools for any cellphone repair are from here. The volume button is available right here. Hope this helps, good luck.
Indice 2
iFixit does not sell parts for anything not made by apple except for game consoles. No guides are available yet for the galaxy S4
Indice 0
get a replacement volume button from here
Indice 0
You need a spudger tool and a Phillips screwdriver.
It is easy to replace a Galaxy S4 volume button.
Remove the battery cover and back housing frame.
The volume button is fixed in back the back housing frame by two clips.
Indice 0
I had exactly same case. I could not use Samsung galaxy 4 anymore
Samsung company made every galaxy 4 volume control switch defective.
many people find out Samsung galaxy 4 defective volume control switch
out of order after use , it became bent right away.
because Samsung company use cheap material less than standard.
Samsung told me 1 year manufacture warranty policy before I bought and then after I bought within 1 year it became defective ,it should cover under warranty
but they sent me email not under warranty.
please watch out Samsung company from Korea and galaxy 4 .
Indice 0
4 commentaires:
This problem is not in volume down button.
actually this problem is caused by overcharging......usually occurs after changing power ic....
not identify where is the problem!!!!!!
par
It's not a charging problem... I broke mine today, I knocked my S4 on the side of my locker at work and it bent inwards and jammed.
par
@Mithun karmakar seriously if you know nothing please shut up. People like you are so annoying.
par
When my volume buttons became faulty on my Galaxy Xcover 4 it automatically went into Safe mode; (which is apparently a normal response to volume button issues).and remained there. I'd like to know if it will still be waterproof afterdisassembly repair and reassembly..?
par
Hi my son the button being poured bubble blower works well but what stands creaks repair
Indice 0
Hi. I would take the phone back to the shop. Gal 4 are having major probe since the new OS - Lolipop. Just an idea.
Indice 0
1 commentaire:
Yeah,all thats problem in not stable lollipop firmware
par
not work volume up how to download mode
Indice 0
I have a galaxy note 5 & I think my otterbox pushed my volume buttons in , when I took the case off , cause my buttons are hard to press on , without the case ? What should I doo???
Indice 0
Ajouter une réponse
Stephen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 52,434
