No Backlight need to find fuse on MOBO
Hello all I am working on an A1229 17 MBP LED unit. Original problem was bezel broke. They kept using it and tore up the cable to the inverter and shorted the pins inside inverter plug. I have replaced both of those parts and now am at board level. I have been searching and searching for the descriptor of the fuse that powers the backlight inverter. Anyone with a schematic or knowledge of the fuse would be much appreciated. I know this is an older MBP but everything else works good. Thank You In advance.
Wade
Update
q9805 was my culprit along with f9800
Wade , what are the last three digits of your serial number? It will allow us to properly identify your logic board and hopefully gives us a chance to help you out.
par oldturkey03
I am looking at a fuse Mouser Part #: 576-0448002.MR which is a 2amp 125 volt fuse, I know the minimum voltage has to be 32 volts. I just want to make sure the ratings are correct prior to ordering. My solder station has a fine tip but even with that, I agree it will be challenging. I plan to just piggyback the fuse on the original one.
Thanks you for all your help.
par Wade
