Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
La Xbox 360 est la deuxième console de jeu de Microsoft, sortie le 22 novembre 2005.
Questions au sujet de 457 Voir tout
My xbox 360 (newer version) won't turn on?
I mean look, I plug it in and when I touch the power button it makes the beep turning on sound but it stays off. Same with the disk input. I don't use HDMI I use the vid 2 for the TV.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 solutions
Réponse la plus utile
Hi, it might be that the cables are faulty. Can u see the xbox showing the green rings? An hdmi cable is not that costly now, so see if u can get one and test with hdmi. Write back on what u did. Good luck.
Cette réponse a-t-elle été utile ?
Indice 2
Commentaires:
It doesn't show any green rings, and I'll try to get an hdmi cable as soon as I can. I'll get back to you when I try it out
par
It didn't work with the cable so I had to go send it in for repairs. Apparently somehow it was wet on the inside? (sorry for the late answer)
par
Common issue with "no power" is a usb port has bent pin and grounding. Visually check your Xbox 360 USB ports. None of the center pins should be touching the casing or outer area.
Indice 1
Commentaires:
All USB Ports are fine, but I've noticed that after I plug in the power and disconnect it there is a delay in the power box.....anything about that?
par
Ajouter une réponse
Johnny sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 4,378
