How to Set the Clock on a 2002 dodge ram
I am having problems with the radio clock, I had to remove the battery and it changed the time. I dont know how to set the time on the clock.
leonel, for the standard radio you should turn the radio on, then press the "Setup" key, the hour will flash. Turn the station control knob left (ahead) or right (back). Then press the station control knob and the minutes should flash. Then turn the control for station again and this should set your time. Hope this helps, good luck.
Followed directions to the letter. No go.
Could be diferent on each car. I had 2 little buttons on the right side said H & M use a pen to press them.
Sorry for the grammer i am dutch.
Worked for me.
That did the trick, Dodge ram 1500 from the 2000'
You have to turn off the radio, then press and hold the time button until the clock flashes, then use the tunning control to adjust the time. Then press the time button again to finish.
The hour flashed but I couldn't get the minutes to flash
Old thread but figured it would help, I didn't know either Push in on the tune knob to change to minutes
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 77
Total : 42,833
1 commentaire
I got a 2007 dodge ram how to set the clock time
par guess69692000
