Aller au contenu principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 questions Voir tout
Display suddenly has pink hue?
This is an early 2009 MacBook Unibody. When using it recently, the display suddenly turned pink. All images and text are visible just with a pink/magenta hue that is uniform across the display. It is almost like the color balance settings were changed but I have confirmed they are normal. I tried resetting the PRAM and SMC with no change. I reseated the connector on the CPU side with no change. Connecting an external monitor (e.g. my TV) works perfectly so it seems to be isolated to the MacBook display. The computer otherwise functions normally. Talk on the internet suggests it may be a bad cable between the display and computer but wanted to gather suggestions here first. Thank you!
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
Try connecting to an external monitor to see if it shows up there. If it does your GPU is having problems, if not your LCD display and/or the display cable is bad.
Indice 2
1 commentaire:
As mentioned in my question, there are no issues on an external monitor. Colors are normal.
Is there anyway to tell if its the cable versus the display? Thanks
par
Réponse la plus utile
It sounds like a problem with the display cable. You're going to need a new display cable. Apple only sells the display as an assembly.
Since Apple does not sell this as a individual part, you will have to either buy a used one that's tested to work or buy a damaged display assembly from eBay. If you have any local small businesses who do 3rd party Mac repair, they may have a damaged assembly with a good cable they are willing to give you for a few bucks, or even for free if they want it gone.
You can find a cable and guide here, along with the link to the full display assembly:
13" Unibody LVDS Display Cable
MacBook Unibody Model A1278 LVDS Display Cable Replacement
MacBook Unibody (Model No. A1278) Display Assembly
Image MacBook Unibody (A1278) Display Assembly
Produit
$99.99
Image 13" Unibody LVDS Display Cable
Produit
$34.99
Indice 3
2 commentaires:
Did Apple have issues with this design? The Display Assembly was already replaced once under AppleCare in Dec. 2011 and this computer has seen LIGHT use the past 1.5 years.
par
Nick - I won't say flawed, more a physical limit as no electrical harness could withstand constant flexing. Apples design is better than most, and more often than not most people don't flex there displays to the point of failure before they get a new system. Yes, a small group do, and it sounds like you and Zuren are in that group.
par
Ajouter une réponse
zuren sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 19
Total : 32,860
