Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Intel Core i5 bicœur avec 3 Mo de mémoire cache L3 de 1,8 GHz
Water spill - battery is not charging but everything else works fine
Hi everyone,
Hope someone here can help with my situation as described below and thanks in advance.
I spilled almost a cup of water on my macbook air last Saturday. I tried to turn it off immediately but it wouldn't turn off and the fan was on high speed for about 5 mins until it turned itself off.
I put it in a rice bag for 2 days and then put it in a room with heater on for a few more days since we haven't had any sunlight this week (really bad timing). I just turned it on today. Everything - display, fan, temperature, keybaord backlit, speakers - is working perfectly fine except the battery. The light on the charger is orange but the battery menu says:
Condition: Replace Now
Battery is Not Charging
Power Source: Power Adapter
I also ran Coconut battery app and it read:
+ Battery Charge
Current charge: 0 mAh
Max charge: 0 mAh
-9.223392e+ 18% (in the progress bar)
+ Battery capacity
Current capacity: 0 mAh
Design capacity: 6700 mAh
0% (in the progress bar)
I'm wondering if anyone knows if it's the problem with the battery itself, the logic board or something else. I don't want to buy a replacement battery only to find it is something completely different.
Any help would be much appreciated :)
Thanks,
Phalkun
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
3 commentaires
Hi Phalkun,
I have the same problem. I am just wondering what happened after you opened and cleaned up your computer? Please let me know.
par
Did you replace the battery yourself? Or had it replaced by an Apple tech? :)
par
I bought tools and a battery from ifixit and replaced the battery by myself. it's really easy. Just follow the instruction on the site.
par
Ajouter un commentaire
5 Réponses
Solution retenue
I meant to update this. My computer is working fine now after replacing the battery :)
Indice 3
I know of no "shade tree mechanics" test for battery, other than placing it in a similar unit and see how it acts... which could damage the other unit. Compare the price of a new battery, or a new DC-IO board. to having Apple or someone else diagnose your problem - Consider the economics of using the money required to purchase a replacement IO board, or battery,- selling the laptop as is, or parting it out, and buying a replacement laptop .
Only you know what your budget and time restraints allow.
Good Luck,
If this Answer is helpful please remember to return and mark it Accepted.
Indice 1
1 commentaire:
Hi @machead3, thanks a lot of your response. We don't have an apple shop here in new zealand tho we have a few authorized shops for Apple. I'm quite reluctant to go there since, from what I heard, they tend to replace the logic boards, which I can't afford.
I'm still waiting for screw drivers from ifixit. I think I'll open it up and dry it properly before going with other options. I just hope it's not a logic problem.
Again, thanks a lot :)
par
I have the same issue. You can change your battery and try again. You can replace the battery if it is the battery issue.
Indice 1
Hi
did you find a solution to your battery problem ?
I have your same problem!
Alberto
Indice 0
any way to diagnose whether this is a battery problem or logic board problem?
Indice 0
2 commentaires:
An initial diagnostic is to measure pin voltages at the connector on the logic board with a multimeter. If there is no output or it's incorrect, logic board is involved for sure, making therefore useless to purchase a battery. This doesn't exclude of course the battery could be faulty too.
par
Thanks, this is pretty helpful!
par
Ajouter une réponse
phalkunz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 42
Total : 7,653
