Steven, right now my concern would be that you need to know that it is not necessary to "to fully melt the solder" for a reflow. I suggest that you get an old board first and practice a reflow. I assume you are going to use a hot air gun. There is a lot more to a reflow than blasting some hot air onto the processor. You could also tell us why you "believe to have a faulty connection between the GPU and the logic board due to over heating." Yes, it is lead free solder. Here are some basic temps that you will need to know "The lead-free alloy used for BGA solder balls has a melting point of 217°C. This alloy requires a minimum reflow temperature of 235°C to ensure good wetting. The
maximum reflow temperature is in the 245°C to 260°C range.
When using a reflow station, for a processor like your NVidia, the profile looks usually like this :
Profile Feature
Average ramp-up rate (Tsmax to TP)
3°C/ second maximum
Minimum preheat temperature (Ts MIN)
150°C
Maximum preheat temperature (Ts MAX)
200°C
Preheat time (Ts MIN to TsMAX)
60–120 seconds
Temperature (TL)
217°C
Time above liquidous temperature TL
60–150 seconds
Peak temperature (TP)
260°C
Time within 5°C of peak TP
30sec
Average ramp-down rate (TP to TsMAX)
6°C/ second maximum
Time 25°C to TP
8-minutes maximum
All temperatures refer to the topside of the processor, measured on the processor body surface. Of course this is for a reflow station based on a lead free BGA IC. Best places to check out first, would be the Xbox360 and PS3 forums. After all, those are the birth places for the home reflows. I attached an image which also shows a common reflow profile. Check this video for a GPU reflow, different computer, same idea. Hope this helps, good luck
A voté
Annuler
Indice
6
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
2 commentaires
Hey! What happened with your mac?
par fjduranr
Hi Steven,
I am wondering, how did the reflow go?
Because I have the same symptoms with a macbook white 2010
Did you do anything else to fix this problem?
thanks for share your knowledge
par David
