I just finished repairing two of these myself... (I have an 8-month-old kitten who likes to chew them)... There was a third that was, apparently, unsuccessful ...
As a previous poster said, there's not much to it, really. Just chop out the damaged section of cable and shortened it up. If I'd been thinking I would have done a video and posted that too...
The biggest "problem" I ran into was the double-helix braided shielding of the outer conductor. I ended up just breaking it into three strands and very gently soldering them back together that way, then eat-shrinking the whole assembly. I'm typing this out on a MacBook running on a repaired PSU right now, so it apparently worked...
Some things to think about if doing this yourself:
1) Try and stagger the inner core and outer shielding solder-points. I was dumb (and in a rush) and didn't, and it's a little bit lumpy now as a result.
2) Make a bloody point of checking the pinout voltages against a GOOD power supply before you jack it in. I screwed up one of the three I was working on (I'm still not sure how. Have to rip it apart again...) and am awfully glad I didn't plug it in...
Good luck!
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
