Dead cylinder no spark.
Changed coils around and still no spark on one of the cylinders. think its the main brain but having trouble locating it. Need help finding it and how to fix it. Kohler Sv740-0020 engine model number 917.288740 Thanks,
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Neal, when you say you replaced the coil, I assume you replaced the ignition module on your flywheel stator assembly. If a new module for that cylinder still did not work, I would next replace the rectifier/regulator. Download the service manual for your Kohler engine from here. It has the trouble shooting sequence for the three different ignition systems that are being used. Hope this helps, good luck.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
Neal sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 123
