Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Version revisitée de l'iPhone 3G avec une vitesse de traitement plus élevée. La réparation de ce modèle est similaire à celle du 3G et nécessite de simples tournevis et outils pour faire levier. Modèle A1303 / capacité de 16 ou 32 Go / coque en plastique noir ou blanc.
Questions au sujet de 1969 Voir tout
Can I hook up phone to computer to see screen
my iphone screen is black so i can't see anything on the screen. can i hook it up to the computer and be able to read the screen? for example read the text messages i have received?
Répondu ! View the answer J'ai le même problème
Score 1
Ajouter un commentaire
Essential Electronics Toolkit
Petit kit. Grandes possibilités.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
1 solution
Solution retenue
Hey, Natalie. I had a 30 pin to VGA connector handy, so I figured I'd test to see if I could get an iPhone 4's image to appear on a monitor by connecting them. Alas, that didn't work -- when I checked the specs of the connector, it said you only get mirroring with the iPhone 4S and higher. So if you have an iPhone 4 or earlier, that won't help. But if you have a 4s or above, this might be what you need: http://store.apple.com/us/product/MC552Z...
Then I stumbled across a website reviewing software called iTools that's touted for enabling you to display the contents of your iPhone screen on your Mac or PC: http://learninginhand.com/blog/2013/3/13...
Please note that I haven't tried this software and can't vouch for it in any way. But if it works, it sounds like it might fit your needs. The review says it works with models as early as the iPhone 3 and that you don't need to install software on your phone, just on the computer.
Hope that helps!
Cette réponse a-t-elle été utile ?
Ajouter une réponse
natalie sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 11
Total : 7,077
