Modèle n° A1367 / 8,16,32 ou 64 GB de capacité
Questions au sujet de 1296 Voir tout
iPod is locked and says try again in 22,353,345 min.
my ipod 4th gen is locked and i am computer illiterate. dont even know how it got the lock put on it except my little brother messed with it while i was at work. i am upset none the less cause i dont know what has happened. i set it up on my moms comp. so i dont have access to it someone please help
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Rpbert Miller, here is what apple says :"
You may be able to reset the passcode by restoring the device.
Connect the device to the computer with which you normally sync and open iTunes.
Note: If iTunes prompts you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes", below.
Right-click the device in the left column and select Back up.
When the backup is complete, select Restore.
When finished, restore from your most recent backup.
When finished, restore from your most recent backup."
If you do not have access to the computer you normally use to sync, follow these instructions.
Cette réponse est utile ?
Score 2
Ajoutez une réponse
Robert Miller sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 99
