AHT - errorcode / what does it mean?
Computer is G5/2,5 GHz - late 2004 (SCI-x slots) - on two of the slots is audio-card + an serial ATA card.
Shall I remove them be4 test by AHT?
The errorcode become under the process when AHT is starting, after the choise of langues,:
THE ERROR MESSAGE IS
invalid memory access at %SRR0 : 00000000 . 010e9ab8 %SRR1 : 10000000 . 00003030
One problem is that i dont have orginal CD, and the AHT is from a newer mac G5, late 2005 (with SCI express slots).
Ive tried that AHT on a older G5/1.8 from 2004 june and then AHT starts. And i also can run the test successfully.
The G5 2,5GHz (2004) is indicating Hi temperature on "memory heatsink" when testing with temperatur monitor - and fan runs up and down all the time.
Ive tried to take all memory away- execpt on par, and change memory on the slots to - thre error code result is the same.
When testing with Techtool pro 4.6.1 - No error.
PLEASE advise mee - what to do?
2 commentaires
Sorry - did find out the reason of errorcodes by myselves.
After removing the audio and sata-card i could start the hardware test. And no problems where detected on the short test, so now is the long version of test running.
My problem is still that fan is running up and down, because of temperatur of 79° celsius in the memory heat sink.
WHERE IS THE heat sinkt detector placed - anyone who knows??
par Goran
invalid memory access at problem ?
par Rabi
