LCD Backlight out after liquid spill (A1377)
Spilled tea (no sugar!) on my girlfriends Macbook last night. Took it apart today and cleaned everything with first 70% then 99% isopropanol.
There was very minor corrosion in a few spots, notably the screen connector.
Today managed to get it to boot and backup in time machine (she had no backup!) However the screen is very dim, I needed to use a headlamp to read it and even so it is difficult.
There was one similar thread (Liquid spill results in extremely dim screen, how to fix?) with no conclusion. I understand some macbooks have a fuse for the screen? Is this the case with the A1377 model and where is it?
6 commentaires
Attach an image (or two) of your logic board with your question. That way we can see what you see and can possibly point out the fuse.
par oldturkey03
image added! there is a part similar to the fuses described in other posts, a brown or orange smc with an N on it. It reads 8.3v on both sides though.
par chris
chris, what are the last three digits of your serial number? Trying to match up the proper schematic for your computer....
par oldturkey03
Serial number is c02dxhnhddr1. If the fuse is indeed the part in the image you have attached, it is OK. Do I consider replacing the led driver?
par chris
These are the specs according to your serial number. Does that look right ;-)
1.86 GHz Core 2 Duo (SL9400)
Intro Date: October 20, 2010 Disc Date: July 20, 2011
Order No: MC503LL/A* Model No: A1369 (EMC 2392)
Subfamily: Late 2010 Model ID: MacBookAir3,2
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 128 GB, 256 GB Std Optical: None*
par oldturkey03
Afficher 1 commentaire en plus
