Version revisitée de l'iPhone 3G avec une vitesse de traitement plus élevée. La réparation de ce modèle est similaire à celle du 3G et nécessite de simples tournevis et des outils de levage. Modèle A1303 / capacité de 16 ou 32 Go / coque en plastique noir ou blanc.
Questions au sujet de 1961 Voir tout
Water damged iPhone On screen volume control not available
My phone fell in a bucket of water. I switched it off and turned it on a few weeks later. Every think seems to work fine but there is no volume/onscreen volume controls!.
in the home screen the whole display seems to work, but in the music app the volume control on the bottem of the screen is blank?
why could this be?
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
thambu, to avoid failure caused by corrosion later on, I strongly recommend that you clean your phone. it is not important how long it was submerged, the simple fact that it was, can give you problems. Disassemble your phone using by following this guide. Clean it using this guide. It was written for a 3G but most certainly still applies. Make sure that you clean all connectors and cable ends and the dock connector as well. Once it is cleaned, replace the battery. Reassemble your phone and re-evaluate. Should you still not have a volume bar, replace the dock connector. For that follow this guide and the part is available right here. Without cleaning it, any answer will only be a guess since this can be caused be corrosion failure of SMD components on the board as well It may have been shorted out. Hope this helps, good luck
Image iPhone 3GS Dock Connector
Produit
$19,99
Image iPhone 3GS Carte mère
Tutoriel
Remplacement de la carte mère de l'iPhone 3GS
Difficulté :
Modérée
Image iPhone 3GS Connecteur de dock
Tutoriel
Remplacement du connecteur de dock de l'iPhone 3GS
Difficulté :
Modérée
Image iPhone
Tutoriel
Réparer un dommage causé par un liquide sur iPhone
Difficulté :
Difficile
1 - 2 hours
Cette réponse est utile ?
Score 1
Ajoutez une réponse
thambu sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 115
