Aller au contenu principal
Souder consiste à relier deux pièces de métal en faisant fondre un troisième métal d'apport entre elles. Il existe plusieurs méthodes de soudure (ou soudage), cet article a pour but de vous enseigner les bases de la soudure électronique.
56 questions Voir tout
Looking to find out best means to learn soldering techniques
Hi everyone,
Looking to find information on the best means to learn how to solder. Often there are cases with my business I require the ability to solder. I have soldered previously however I find it frustrating when the solder does not stay on the part being soldered. I have read about adding flux and temperatures and a host of other articles which were not helpful.
How did you learn to solder?
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
3 Réponses
Solution retenue
This is kind of like asking, "how do you ride a bicycle". Practice, practice, practice.
Start here: Soldering
Solder
Solder is used to create a non-permanent electrically conductive connection between non-ferrous metals. The relatively low melting point of lead/tin (Pb/SN) solder is a perfect match for sensitive electronic components. For applications where lead is not desired, one good substitute is "no lead" solder - usually a mixture of tin with a trace amount (0.3%) of copper. Note that most so-called "silver solders" are lead/tin with about 2% silver added. Lead-Free Solder
Stuff you may need: Soldering Workstation
Comment souder et dessouder des connexions
Here's some more extensive reading on it: http://www.instructables.com/id/How-to-s...
Image Lead-Free Solder
Produit
Lead-Free Solder
Image Soldering Workstation
Produit
$49.99
Indice 3
Utube
Indice 0
Thanks Brian.. Never thought of that..
Indice 0
Ajouter une réponse
new2usedcomputers sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 601
