After H20 Damage, iPhone only boots with battery out
I bought a water damaged phone on ebay. The dock connector ribbon cable was downright ratty, so I replaced it, the battery, the LCD/front glass, and the rear glass. I noticed the phone would not charge - it would only get really hot when I plugged it into a USB wall charger.
I tried to boot the phone with the battery out, and it works right away. When I plug it into the wall with the rear glass off, the INSTANT I take out the battery, it boots up. Does this mean I got a bad battery from the ebay seller?
The only downside is that it won't boot off of USB power, so I can't format / restore the phone to use it. I also desoldered / re-soldered the battery FPC connector to make sure everything is good there. I lifted a small capacitor during this process, but I've read the capacitors should not be replaced if lifted. (This happened AFTER discovering the boot w/out battery.)
Should I simply order another battery, or has anyone else had a similar issue and can tell me what to do from here?
what is your definition of " lifted a small capacitor"? when you plug your phone in, what voltage do you measure at the battery connector (L and R contacts) with the battery removed?
par oldturkey03
I measure 1.21V across the L and R contacts with the battery out and the phone plugged into a DC adapter. There are two small capacitors right next to the battery FPC connector (to it's upper left, when looking at the back of the phone with the dock connector down). I lifted the one closest to the battery port. I accidentally hit it with the soldering iron and it came off.
par Casey Friday
The home button and power button are both also unresponsive during all of this.
par Casey Friday
I've just ordered a new Flex Cable and Home Button ribbon to add them and see if they fix my issue of no power/home button responsiveness. I really hope that fixes this phone, because I've put quite a bit of effort into it at this point.
par Casey Friday
1.2 volts is definitely not enough. You should have something around 3.9V+ post an image of the damage to the logic board. It is possible that you are having PMIC issues.
par oldturkey03
Voir 8 commentaires en plus
