La famille des Macbook a été introduite pour la première fois en mai 2006, pour remplacer la gamme portable d'Apple, les iBook.
Questions au sujet de 4069 Voir tout
Various Laptops with Power Issues
I have, over the past few years, have what seems to be the same issue with 4 different laptops.
About 3 years ago I had a Compaq Q60 laptop, one day I plugged the charger in and noticed there were no lights and it wasn't charging - the laptop continued to work till the battery went flat. After googling my issue it seemed like this was the norm for these laptops so I didn't bother fixing it. I decided to buy a new MacBook Pro 13". 14 months later I had the exact same thing happen as did with the Compaq. Once again after googling, I replaced the DC jack (see my first question in regards to this issue) but this didn't fix the issue. After months without a computer, a friend lent me his newish HP laptop, after a couple of months the SAME thing happened, I thought it may be the charger so I did nothing. About a month ago I then brought a used Macbook 13" (not a MacBook Pro) and placed my Pro harddrive into it and had a perfectly working mac, until last night SAME thing. Although I did notice that when I plugged the charger in the green light momentarily came on then went off and nothing since - is this all just a coincidence or what?
One thing was that I was using the same power outlet each time the laptops "died" but I have other electrical appliances (TV, DVD etc) using it too and they're fine. I'm at a total loss
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Seems to me you're hard on laptops. (4 in 36 mos - minus some downtime with no laptop at all).
Following the charging/discharging/use guides of the manufacturers is essential to battery life Every battery has a finite life. This life can be drastically shortened by misuse. or, extended with care.
I think I would invest in a UPS power supply/battery backup to ensure a normal steady current to the laptop at all times (brown outs e.g. current/voltage drops, are worse than power surges for computer hardware). Other hardware is more robust/forgiving - might even have some onboard protection... (for that mater you may have 4 laptops with tripped fuses on logic boards or inside batteries -todays batteries do have onboard logic/charging circuits-).
It might be a good idea to have your home wiring checked... especially that outlet
If this Answer is helpful please remember to return and mark it Accepted.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
Lisa sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 72
