Aller au contenu principal
Guides de réparation et de démontage pour Apple Time Capsule Modèle A1302. La plupart des informations s'applique également au modèle A1254.
Questions au sujet de 18 Voir tout
time capsule dead, hard drive possibilities?
My time capsule will not work, I have tried everything. What I want to know, can it be wired just to be an external hard drive? Can I place an OS on it and use it for storage? Reformat? Basically I have pulled it out of the case and want to know has anyone rewired the connections to have it work, it seems a waste to have a TB hard drive and having it sit static.
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
3 Réponses
Solution retenue
Which hard drive do you have and does it have standard SATA connections?
The hard drive typically found in a Time Capsule is the Hitachi Deskstar, which is sold by Hitachi as a consumer-grade product—the Hitachi Ultrastar is the enterprise version.[13] Apple labeled the drive as a server-grade drive in promotional material for Time Capsule, and also used this type of drive in its discontinued Xserve servers. Apple states that the Hitachi Deskstar meets or exceeds the 1 million hour mean time between failures (MTBF) recommendation for server-grade hard drives.[14]
The 500 GB, first generation Time Capsule shipped with a Seagate Barracuda ES-series drive.[15] More recently, other hard drives such as the Western Digital Caviar Green series,[16] and the Samsung EcoGreen series have been reported.
Indice 1
If your question was can I connect this HD to my Mac system directly via the universal SATA adapter.
The answer is no, this HD uses a different format. So you can't recover any data from it nor can you prep the HD via your Mac. The AirPort Utility has the needed functions to prep a new HD if you swap it out.
Indice 0
To further the discussion: My first generation Time Capsule power supply failed, and I bought a new TC. I have removed the old Seagate Barracuda ES hard drive and want to get a power supply so I can retrieve data on it. Can I buy an external power supply of some kind?
Thanks,
Phil
Indice 0
Ajouter une réponse
Paul Hicks sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,828
