Broken on off switch
Acer customer service tells me that the on off switch is an integral part of the mother board and I need to replace the mother board at a cost of over $200. Is there a way to fix the switch or should I just trash it. My internet research indicates that this is a known problem with this unit but I have not yet found a solution.
3 commentaires
Dennis, my Acer Iconia has the same problem, the on/off switch is stuck inside the tablet and unable to reset it. I would like to know where you had yours serviced so I may get mine worked on..thank you in advance for your help.
par mummerydw
Mine was done by a local tech at a repair shop in Las Vegas. I had to try several repair shops before I could find someone who was willing to try. I had a very good idea what was wrong and had taken the back off before I went to this shop. After he took a look at it he was willing to try. You might have some luck with the same approach. I doubt that my shop does mail order work but if you can't find someone locally let me know and I will ask if they are willing.
par Dennis
I am in Atlanta, GA and I have the same problem with the power button on my Acer A500. Does anyone know were I can get it repaired or have in structions on how to repair it?
Burrell
par Charlie
