Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
Questions au sujet de 270 Voir tout
17" iMac 1.83 with lines on screen
I have an Intel core duo imac g5 17" 1.83 and it has a built in cam. I'm confused as to what model of lcd is used to replace my lcd, as it has the ever so common and annoying lines in it. I also see 2105 at the bottom of the stand. Which models of screens (I presume must be with isight?) can be used to replace mine?
Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Commentaires:
You do not have a G5. It is an Intel processor machine.
Apple iMac "Core Duo" 2.0 20-Inch Specs
Identifiers: Early 2006 - MA200LL - iMac4,1 - A1174 - 2105
par
Ajouter un commentaire
1 solution
Solution retenue
You will have to dismantle the machine to replace the screen. On the back of the screen is the manufacturers ID number. With this number and Google Shopping you should be able to find a replacement or compatible screen.
If this Answer is helpful please remember to return and mark it Accepted.
Cette réponse a-t-elle été utile ?
Indice 2
Commentaires:
Thank you machead3. I'll give it a try.. never disasembled it before but will give it the old college try. I'm just wondering if it should be specified with isight and als.. which I assume is correct.
par
To get you to your correct machine please give us the last three figures of your serial number located on the bottom of your stand. I think I gave you the 20" machine instead of the 17".
par
This is an advanced DIY repair.Study the guide before you start, obtain the proper tools, keep all parts well identified. You are going to replace the LCD screen only. The camera will be reused (they are separate parts.
par
Ok thanks machead3.. and the serial number is W860516SU2N mayer. It's the 17" model, is that the correct serial number you were looking for? I think there's only one serial on this machine.
par
Ajouter une réponse
David Sutton sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 749
