Sounds like this could be caused by a few different things.
1. Software, IOS is awful at calibration, even after a week or 2 problems can arise that weren't there to begin with.
Try reseting the device by holding both power and home buttons until the screen has gone black and the apple logo has appeared. Backing up and re installing IOS may help resolve this issue as well.
2. Shorting, any ESD (Electro Static Discharge) can cause the digitizer in the screen to act strangely i.e. ghost clicks and unresponsiveness.
Open the device and check that no screws are out of place, also check the flexes for any damage.
3. Faulty Hardware, the part that you have been supplied may be defective.
If none of steps 1,2 help contact the supplier of your screen and get them to swap a new screen with the faulty one you have been given.
Hope this helps :P
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
