Sorti en octobre 2008 / Processeur Core 2 Duo à 2.4, 2.53, 2.66, 2.8 ou 2.93 GHz
Questions au sujet de 442 Voir tout
Battery not powering Mac, New Battery, New Power Logic Cable.
Hi,
i have replaced the Battery, and Logic board battery cable, computer still only works with the AC, turns off IMMEDIATELY after AC is removed... is the next step a new logic board??? $600 question....
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Help us help you. The more we know for certain the more help we can be.
The trigger that caused you to decide to replace the battery and logic board cable certainly can could be the reason why the machine suddenly shuts down after the AC power supply is disconnected.
If there was a liquid spill it would not be out of line to replace a damaged logic board, and a liquid spill could cause the problem you're having. So might a power surge.
Examine the logic board under a magnifier… look closely for burn marks, corrosion or swollen components. If you find some that would indicate a logic board replacement… DIY component replacement requires special tools, solder and lots & lots of practice… it's nothing like soldering a lamp cord.
If this answer is acceptable please remember to return and mark it.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
logan sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 101
