upgrading to 2 ssd raid 0
after installing the ifixit dual hd kit & creating the raid 0 [with the 2 ssd drives in disk utility]
- when restoring the boot drive to the raid this error shows *
"restore failure an error (32) occurred while copying. (Broken Pipe)"
please advise on any ideas of what's wrong
- already tried * different block sizes like 32k - 256k
- ssd drives are both Sandisk 256 gb Ultra Plus
11 commentaires
thanks for the reply
the 2 ssd drives are the same (sandisk ultra plus 256gb)
- are you suggesting that if I transfer the boot partition to a faster drive before transfering to the ssd raid?
• [the boot partition is currently on a typical 500gb hard drive]
par macmini
the plan is to switch from one 256gb ssd to two 256gb ssd drives in raid 0. the 2 ssd drives have previously been used as boot drives in the 2011 mac mini & early 2011 15" MBP
par macmini
the 500 gb drive the mac mini came with is currently in use as a bootable backup.
par macmini
RAID 0 stripes the data across the two devices. By design the I/O to the devices and the devices them selves need to be Matched as there is no way to buffer the write or the read if one device is slower or if the I/O to the device is slower in a RAID 0 setup. In this case the I/O path is not the same here as you are using the slower optical drives SATA connection. Other versions of the mini offer dual SATA ports that are the same speed and offer RAID 0 as an option (server models).
par Dan
both drives identify as 6 gigabit on system report
par macmini
Voir 6 commentaires en plus
