Why won't the battery charge?
Hello, I have a macbook pro 13" that was given to me after it was thrown down cement stairs. I replaced hard drive, hooked it up to external monitor because screen will not turn on, only get a white screen then goes black. No damage to screen at all on outside. The keyboard and trackpad will not work. Battery will not charge I need to plug in to work. It has internet, video, works great by using bluetooth keyboard and mouse. I check all wires and logic board for any damages I can detect and see none but I am a novice at this. I removed theLCD LED LVDS Cable, cleaned it but still not screen. What could be wrong with battery not charging? I did order a new lvds cable to replace.
and would like instructions on replacing this cable.
thanks Lynn
2 commentaires
It reads current charge not available, max charge NA, Current capacity NA, Design capacity NA, It tells me the correct info on the model and age. Battery load cycles NA, TEMP. NA, Battery power usage NA. The top case is dented on the left side where all usb and slots are and is curved up. I can send you photos of case and logic board if you would like.
par Lynn Heiser
I added photo of macbook pro and logic board near the cable. I have more of the logic board to show you to see if you can see any damage.
par Lynn Heiser
