Aller au contenu principal
Écran de 7,9 pouces / Modèle A1432 / Disponible en noir ou blanc / Annoncé le 23 octobre 2012/ avec 16, 32 ou 64 Go de capacité
220 questions Voir tout
LCD flickering after digitizer replacement. Tried new LCD, still same.
The LCD had no issues when the customer brought in the ipad mini. When I replaced the digitizer, the lcd was all greyed out and 2 black lines running down the middle. I assumed it was a bad LCD so I tried a new one and the same problem persists. Could this be a board issue? If so, is there a fix?
Tried hard reset, same issue.
Original LCD http://imgur.com/tonBntl
New LCD http://imgur.com/NZk3zeS (red is to protect customors identity, not on actual lcd)
Répondre à cette question J'ai le même problème
Indice -1
Ajouter un commentaire
2 Réponses
This is probably a logic board issue. What most likely happened is that a connector was damaged. You may need to replace it.
Indice 0
1 commentaire:
Thanks, that's what we thought. We'll try apple and see what they have to say.
par
Were you able to fix your problem? I am confronting the same issue. The screen is flickering(the image jump and jump all over the screen) Both LCD I have tested so far are broken inside, so I don't know if this flickering is caused by the broken LCD or by the connector.
Let me know, thanks!
Indice 0
Ajouter une réponse
Robert sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,042
