This problem has been recognized by Samsung, it's a factory thing, all You need to do, is open your tab, remove the battery cable for about 10 mins and plug it back again, unplug the screen from the motherboard, and charge it for about, two hours, then plug back the screen connector, and turn it on, if you see it works, turn off the tablet again, and plug in the power cord again, you'll see the charging animation starts, leave it charging for the time you think it's necessary to reach 100%, unplug the cable and turn it on, your tablet is alive, the only problem I've found about this, is that you'll need to turn the tablet completely off whenever you want to charge it, and finally this, VERY IMPORTANT! When your tablet is below 15 or 10% battery, charge it, because if you let the battery die, probably you'll have to do all the steps again.
A voté
Annuler
Indice
50
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
117 commentaires
so I've had my tablet for a year and like over 5 mouths now it doesn't wanna charge I've tried my lap top tv and the out let but nothing even if i put my finger on the power button it won't turn on does any body know how to fix this problem if you know please help me
par shandy
My grandson has an asus tab that won't charge or turn on anymore. Only had it 3mts. Help
par perrinkatrina
I have my tablet for over 4 years, but after i install an upgrade, my tablet doesnt charge, but the screen is still on. Help me out
par Sky Xplorer
my tablet will not turn on. i charged it all night. i held down the power tab what usually works, but its not working. i dont have a clue on how to take out the battery. in need of some asisstance.
par ladycinda2004
My tablet totally blank .I put it on charge but it is not charging
par Maninder Sahota
Voir 112 commentaires en plus
