Aller au contenu principal
Ipad Mini 7,9" avec 16,32 ou 64 Go de stockage.
630 questions Voir tout
No touch response after replacing Screen
I had a broken screen so i decided to get a new one and then as i put it together the home button nor the power button worked. the power button only works to turn off but my screen don't respond to any of my finger touch can someone please help?
Répondre à cette question J'ai le même problème
Indice -1
1 commentaire:
Did you buy a preassembled unit i.e. with the ic chip or did you solder it yourself?
par
Ajouter un commentaire
1 Réponse
Assuming you purchased the digitizer with the IC already soldered onto it you could be looking at several different problems. Check these trouble spots first.
First, check the digitizer IC socket on the motherboard, examine the pins inside the socket itself. If any of those pins look : dirty, not sitting even with the others, missing or damaged in any way this will render the touch input completely useless. A dirty pin can be cleaned using isopropyl alcohol and a q tip, anything other than a dirty pin will more than likely require that socket to be replaced by a professional.
Second is to make sure you transferred the the tape on the home button ribbon from the old screen to the new screen. I havent seen this issue affect the touch input but it will occasionally mess with the lock and home button operations.
Third, when sealing the new screen to the frame be very specific about how you feed the cable down into the frame, aftermarket digitizer ribbons are fickle when it comes to bends or creases. Some will work after being creased some will flat out refuse to work or cause "ghost input". Basically none of the cable should be pinched between the frame and glass once you lay the glass flat on the frame and it should be fed in a "S" style while doing so. If it is already creased its a fair bet youll need a new one.
I hope this helps and good luck getting your iPad mini working!
Indice 0
1 commentaire:
do i have to solder it? i just removed my cracked screen and put my new one exactly how the old one was but nothing. although i did have to remove a boxed part that goes to the iPad and replacement screen cause the new one didn't come with it. and thanks for ur answer too
par
Ajouter une réponse
Jose sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 417
