I hear a click as if the adhesive did jack and then let go
after about two months that I glued the glass ipad 3 if I press strong in some points of the frame I hear a click as if the adhesive did jack and then let go ... I can feel comfortable or do I take off again and add the glue? in which case glue can I use? thanks (I state that the glass does not seem relieved than the small plastic seal "bezel")
Thanks for the reply Joshua, I'm sure that the 'LCD is fully assembled. I'm a fairly accurate and this will be at least one twentieth ipad dismount, only just a few times the digitizer does not adhere perfectly right .. of course you have to press very very strong to notice the problem, and I realize that the aftermarket will not be as double-sided the original apple ... but I was wondering why ... andrea
par AndreaBaglione
