Aller au contenu principal
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
Questions au sujet de 42 Voir tout
"No Sim detected" problem
The Sim card detection suddenly stopped. Whatever service is put in, no SIM card detected.
What might be the reason?
What is the Fix?
Thanks,
Ravi
Répondre à cette question J'ai le même problème
Indice 10
Ajouter un commentaire
6 Réponses
Réponse la plus utile
I found that my issue was that there is a piece of metal at the bottom of the SIM card slot that when you put it the sim it connects with a sensor that tells the phone a sim is inserted. But the issue is the metal cage does not cover the full sim area and the metal arm can dislodge at the bottom and doesn't connect. I had to take the back off and push the arm back in alignment to have it recognize the sim again.
Hope this helps,
Indice 5
A simple solution/work around to this issue involves placing a small piece of tape or paper behind your phone's SIM card and sliding it into place as normal, don't force it, it should slide in smoothly with no extra force needed. If done correctly, this may make your SIM card fit more snug into the SIM card tray and enhance the SIM card's connection.
Indice 2
I have this Problem after "NO" remedy finaly went to shop who change the Jacket which cost me a good amount
Indice 1
Hi,
I had the same problem and I've found a solution of that problem in youtube. Have a look it might help you as well.
https://www.youtube.com/watch?v=gfNUu4Dj...
Thanks
Indice 0
Geniiioooouuussssss!!!!! Thanks a lot!
Indice 0
1 commentaire:
Which answer helped you?
par
SIM card in my phone but
No SIM card shows me
Please halp mee
Indice 0
Ajouter une réponse
Ravi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 24,059
