Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Also known as the Incredible 2, the successor of the HTC Droid Incredible is identifiable by the model number S710E.
Why Battery is not charging fully?
Hi,
My incredible S doesn’t charge fully, max can charge 47% only, after that there is no improvement keep showing amper indication only, I have tried with 3 ROM but result is same. Then I have changed battery still same, I tried in different way to charge my batteries fully (2 x new battery) then insert in, still result is same. Someone please help me what could be the problem? Why phone doesn’t charge/show to 100% and not turn it to Green. Is phone main board problem? Or better change the phone? I am totally struggle with this phone. I suspect power IC is a problem. what is the solution for it?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Réponse la plus utile
May be that where you charge the fone from are missing its 'Teeth' i would advise you to take it to get seen to as i had this problem with an old fone. And it was soon sorted :) I hope this helps you.
Indice 1
Sir, jab apna mobile phone htc s710e charging ke liye lagata hon to indication a jati hai but battery ki parcentage nhi bhadti hai.
plz reason bta dein.Thanks
Indice 0
Ajouter une réponse
spb sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 15
Total : 1,840
