6ème génération de l'Apple iPhone, annoncé le 12 septembre 2012. La réparation de cet appareil est similaire aux précédents modèles et nécessite des tournevis et des outils pour ouvrir et faire levier. Disponible en GSM ou CDMA / 16, 32 ou 64Go / Noir ou Blanc.
Questions au sujet de 3313 Voir tout
Opening my iPhone failed...
Hi !
I I was just trying to open my iPhone 5 with a suction cup and a plastic opening tool, just like in battery replacement guides, just like I successfully did with other old devices... My problem is that not the entire front display famed when I pulled the cup... The display came alone, leaving the rest (I mean the part where the home button on the iPhone... And I now absolutely do not know how to continue opening it...
You want something worse ? When I pub the display back in, the iPhone does not boot at all...
I'm waiting for your advice to know how to open it now and try to figure out what's going wrong.
Thanks !
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
Vous avez déjà réparé quelque chose ? Vous êtes un génie.
Partagez votre réparation avec le hashtag #ImAGenius
Nous sommes tous des génies
1 réponse
Solution retenue
On bottom left corner stick a flat head scree driver between the metal frame and plastic bezal and pry up
Cette réponse est utile ?
Score 1
Commentaires:
I succeded opening the iPhone, but as I told before, the iPhone is no longer starting... I thing that the whole front panel assembly and probably other components have been damaged.
Mabe will I try to fix it in a more or less near future but for now I can only tell my iPhone to rest in peace
Thanks anyway I accept your answer because even if my phone is dead, this is probably a good way to open the i5.
par
Hi there have you tryed plugging into iTunes and see if it's recognised?
If so and it's recognised then a screen change could be all you need
par
Ajoutez une réponse
Vincent Monteil sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 81
