Aller au contenu principal
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 questions Voir tout
i5 2.8, 4gb, 5750 upgraded to i7, 16gb, 6970 - stuttering graphics?
I have upgraded my mid 2010 imac i5 using a bunch of guides on here from:
  • cpu: i5 2.8ghz
  • ram: 2x2gb
  • gpu: radeon 5750 1gb
to:
  • cpu: i7 2.93ghz
  • ram: 4x4gb
  • gpu: radeon 6970 2gb
(+second SSD installed under optical drive)
the system was running fine with only the ram, SSD and cpu upgrade, but since i replaced the gpu, i get stuttering performance in games, i.e. the frame rate drops to about 5fps for 10 secs and then comes back to normal for 10 secs before dropping again.
this happens in all my games and both in os x 10.9 and bootcamped windows 7. Temps are around 80°C, which is similar to my old gpu.
when in a game's 2d menu that has a 3d background, the cursor will stay responsive while the background stutters.
my thoughts so far:
  • faulty gpu?
  • wrong drivers? (amd auto detect didnt get the name of the card but said drivers are up to date)
  • psu not putting out enough power? (all the upgrades require more watts)
any comments? i really dont want to put the old card back in...
[edit] Using ati overdrive, i found that the card will fall into low performance mode which means 100mhz gpu clock and 149mhz memory clock. how do i stop that?!
[edit2] I was able to force the card to stay at normal clocks in bootcamp, but GPU-Z read nearly 100°C on one of the sensors.
I have removed the card and reapplied thermal paste.
Also I have moved the SSD away from under the optical drive because it was blocking the air flow to the gpu heat sink. It is now sitting next to the HDD under the gpu'd heat pipes.
[edit3] I'm using Macs Fan Control to make my fans spin up earlier because the card doesnt like temperatures as high as apple's default settings do.
Max temp is 78° while under heavy load, thats good enough. fans at max speed obviously...
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Have you upgraded your OS (what OS are you using)? Have you upgraded the EFI? Both those come into play with the graphics change especially. Lots of free space on the boot volume? (15% of total drive size). Any or all could contribute to video performance issues.
If this answer is acceptable please remember to return and mark it.
Indice 2
2 commentaires:
Mac OS 10.9
Upgrade EFI? how?
par
Check here. FWIW I would not be running 10.9 unless you have some software or peripheral that demands it. There have been many issues with that OS.. 10.8.x was/is pretty stable. I wouldn't rule out your video problem as stemming from 10.9 try running 10.8 and see if there's an improvement. Connect to an external monitor - see the same video behavior, likely GPU/logic board - but if the behavior is absent it points to internal display chain.
par
Ajouter une réponse
jes ta sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 308
