Aller au contenu principal
Le plus large parmi les MacBook Air Apple, disposant d'un microphone double et d'une connexion Wi-Fi 802.11ac.
464 questions Voir tout
Question close
Liquid damage - no LED on MagSafe - power on pads
SITUATION
I have a MacBook air 2013 13-inch i5 with slight liquid damage. Any residue and liquid has been removed as I have done successfully with many laptops.
I get none of the following:
- chime
- LED sleep light
- keyboard lights
- screen display
- LED light on MagSafe
- fan
The original MagSafe light still does not come on. Tried getting the Magsafe light to come on while installed and after removing it from the computer. Tried various MagSafe chargers. Cleaned MagSafe port and charger tips. No light.
On MacBook Pros were able to plug the MagSafe io board up to a power adapter and the MagSafe LED illuminates.
• Shouldn't the new IO board light up when connected to a MagSafe charger BEFORE installing it?
• (those of you with actual experience) Can the MagSafe charger other than Apple's recommended 45 watt be used to power on this laptop?
PART TWO
Where are the power on pads on this logic board?
PART THREE
If anyone has similar experience or has had success with this particular problem, I'd love to hear the details of your remedy.
NOTE: (not yelling) YES I KNOW THE NEXT STEP IS TO HAVE THE LOGIC BOARD PROFESSIONALLY CLEANED AND/OR REPAIRED BY A COMPONENT LEVEL REPAIR SHOP. RIGHT NOW JUST TRYING TO GET ANY KIND OF ELECTRICITY TO GO THROUGH IT AT ALL.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Does not look like it has power on pads. The only thing that remotely looks like it might work is to shorten pin 11 to ground on your IPD Flex Connector
par
Ajouter un commentaire
3 Réponses
The question is how much liquid got to it and where was the spill. Did you find any evidence that it actually go to the logic board or Mag-Safe board? Have you used a multimeter to test the output of the adapter? Here's the pin out on the mag-safe (right side of the page:
http://en.wikipedia.org/wiki/MagSafe
Indice 0
1 commentaire:
I really couldn't find much evidence at all of liquid exposure. What there was was on the far opposite end of the logic board away from the io board.
Thanks for the pin out guide. I'll check it tonight.
I REALLY REALLY do appreciate your fast response. Quite amazed. Thank you. I'll be back with my findings.
Sincerely,
Chris L
ACHDS
par
Swapped out the io board with a new, known working one. Still no light or occasionally a VERY dim green.
I tested it before I put it in the MacBook Air. Shouldn't I get some kind of response on the magsafe tip that lights up (on the end of the actual cord)?
I'm starting to think that it's the power key and keyboard. Help?
Thanks.
Indice 0
yes, I would replace the top cover as well.
Indice 0
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 560
