Will not respond, battery replaced goes flat and then the same problem
I have recently had three iPhone 5's with the same problem, the problem is that it would not respond to anything tried hard reset and plugging the iPhone in to the mains but still nothing.
However when I replaced the battery it powered up and everything worked fine until the battery ran flat and has reverted back to the same problem.
Just a shout out to see if anyone has had the same problem and to see if there is a fix or not.
Best regards Tom.
2 commentaires
I take it the charger works grand when the phone is on?
par con
Yeah the charging port works fine, i did replace the charging port but had the same problem the only thing i think it could be is something to do with the main board. Alas my knowledge of board repairs is quite low.
par Tom
