Modèle A1419 / Fin 2012 / Processeur 2.9 & 3.2 GHz Core i5 ou 3.4 GHz Core i7, ID iMac13,2
Questions au sujet de 212 Voir tout
Why is the thunderbolt port not reading my FW External HD?
I have an Apple Thunderbolt to Firewire 800 adapter that I use to plug in an external hard drive. When connected and the HD is turned on it does not show up on my system or system profiler.
However when I used the same adapter and ext. HD on my Macbook Air, the drive shows up without any issues.
I have tried to reset the system by unplugging all connections included the plug itself and holding the power button for 20 seconds then rebooting but this has not helped?
Someone mentioned to me that it may be the logic board itself. Can anyone assist in resolving this issue?
Une réponse ! View the answer J'ai le même problème
Commentaires:
Is the external drive Firewire 800 or Thunderbolt?
par
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
Avez-vous jamais réparé quelque chose ? C’est génial.
Share your repair story with #ImAGenius
Nous sommes tous des génies
1 réponse
Solution retenue
Do you have access to another Thunderbolt device to connect to your system?
I would start there to double check your systems port. If it is working then its likely a driver issue, otherwise the adapter may not be fitting correctly.
If the other device also fails to work then you do have a bad logic board.
Cette réponse est utile ?
Score 1
Commentaires:
Yes, I tried it on my Macbook Air and the external drive showed. Same settings. Thunderbolt to Firewire800 Adapter. It is still under warranty so I'm taking it in for repairs.
par
Ajoutez une réponse
Rondell sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 1,068
