L'Apple iPhone 5s fut annoncé le 10 septembre 2013. La réparation de ce modèle est très similaire aux modèles précédents et requiert des tournevis ainsi que des outils pour faire levier. Disponible en version GSM ou CDMA, 16/32/64 Go de stockage et en argent, doré ou gris sidéral.
Questions au sujet de 3786 Voir tout
iPhone 5s's battery with separate charger flex.
Due to persistent problem with iPhone 5s's battery - don't you plan to make your own flex tray with integrated charger ?
It can be even, probably, with micro-usb connector )
My 5s has lot of problem with charging.
I replaced battery, but it hot like !@#$ now (
And there are no proofed solution for me (
Une réponse ! View the answer J'ai le même problème
Commentaires:
What are you talking about?
par
Battery was replaced already - phone still hot and discharging very quickly.
Dock connector is on the way from eBay.
I think it can be connected with it because looks like phone frying any cable connected to it - all of them stopped working after a time - and starting write "Accessory not supported" - first one died my original cable which come with phone.
Unfortunately - I did not found any service here - in Russia for free (
If it's a charging circuit on the logic board - it'll cost about $200 - $300 to repair it here.
I'm very disappointed in Apple quality now...
It's my first and last iPhone I guess ...
I bought top model of Apple iPhone (5s with 64GB) not for such service surely...
par
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Alex Tches, sounds like your 5S is not charging and you are looking for an external charger. No external chargers are available. Sounds like you are also saying that your battery is getting hot. The phone should still be covered under warranty, so try to get it repaired/replaced that way. Otherwise, this could be caused by a defective battery, a bad dock connector or a bad charging circuit on the logic board. I'd start with a battery, but only if the phone is not covered under some reason by warranty. Hope this helps, good luck.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
Alex Tches sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 131
