iFixit is for fixing things, not for this kind of project, but i'll answer you.
As you posted this question it is obvious that you didn't made a google ressearch, there are hundreds of well documented tutorials.
There are two ways to build a drone :
°First you go to a specialised model making shop and just buy parts to assemble together (structure, motors, variators, control board and radio, batteries)
°Second solution, have to buid yourself the parts mentionned above. Built the structure with some wood for example, use some microcontrollers and sensors for the control board (or arduino if you are a beginner), use radio tranceiver then finaly code the µC. It takes first a lot of time for designing it and understanding how everything works.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
"I am making a project.. and i don't want it to look like that i bought it." what did you have in mind?
par oldturkey03
I was thinking about buying the thing and then try to change the shape thats all !!!and i was thinking that people here might help me getting the boards and the components... and then no need for me to buy the thing ..
par khalifa
You need to tell us a bit more about what ideas you are having. So you want to buy it and then what? Explain this a bit better as well "getting the boards and the components... and then no need for me to buy the thing"
par oldturkey03
